TwinTurbo.NET: Nissan 300ZX forum - will there be up and down movement in 3rd gear with throttle (n/m)
Jiro
on March 04, 2012 at 7:36 PM
PAR Engineering transmission gears >>>
posted by LitlElvis
on March 04, 2012 at 06:54 PM
LitlElvis
18:54:13 03/04/12
Do you know how loud these will be? (n/m)
KongZTT GT28RS MD
19:15:52 03/04/12
Id say its probably somewhere in the ballpark of this....
jmt-z
19:35:19 03/04/12
I'm sure it will sound something like reverse gear does
LitlElvis
21:00:36 03/04/12
Thats okay for a race car, but the noise is like an old
CmyZ
22:44:41 03/04/12
Interesting. (n/m)
Boosted1
19:31:42 03/04/12
will there be up and down movement in 3rd gear with throttle (n/m) -
Jiro
19:36:09 03/04/12
Up and down movement of the shifter or...? (n/m)
LitlElvis
20:58:23 03/04/12
Wow! (n/m)
BoneZ (MD)
20:05:06 03/04/12
So this will allow clutchless shifting through 3rd
ShakaShaun(Denver)
20:41:14 03/04/12
Don't confuse straight-cut or helical gears with clutchless.
LitlElvis
20:57:08 03/04/12
So with these it's fast shifts only or you grind right?
Jayru
22:22:10 03/04/12
its like a truck, if you time it right you can shift with
live4strength
23:11:53 03/04/12
While you are at it you should weigh stock components to the
5280Z_nightstalker
01:38:17 03/05/12
I would have to say par would be heavier. big heavy gears
fst300zx
06:33:31 03/05/12
what normally breaks on OEM, thought it was just the sycro's
JaffaUK
02:30:07 03/05/12
Re:par
BLACK Z
06:31:48 03/05/12
I like the OS Giken ratios
Rob'Z
07:32:18 03/05/12
Surprising someone is taking on the expense to produce these (n/m)
08:43:17 03/05/12
Very nice, I checked the replies but didn't see it asked
09:20:52 03/05/12
PAR states "no extra cost helical gears or custom ratios"
LitlElvis
10:40:10 03/05/12
Agreed on the sychro philosophy
11:26:40 03/06/12
using a clutch with a lightweight disk also helps syncros (n/m)
aliaZ
07:31:13 03/07/12
